Paskutinis prisijungimas: Dabar yra 2026 Lap 26 02:17
 Pranešimo tema: nike air pegasus 89 men's
StandartinėParašytas: 2021 Bir 05 08:39
Užsiregistravo: 2021 Bir 05 08:18
The men's Nike Air Zoom Pegasus 37 delivers the same consistent running experience scratchlin.com as Pegs of the past, but it has a new look and feel thanks to updated components. Even with the changes, though, the Pegasus 37 remains a light, fast and cushioned neutral running shoe that’s ideal for everyday training and races alike.
Nike React foam at the midsole is lightweight, springy and durable. More foam means better cushioning without the bulk. An Air Zoom unit at the forefoot nike sneakers womens white provides energy return, adding a pop to your step as you run.A translucent upper has the look of speed and is made to help your foot while you run. Mesh throughout adds to that transparent look while helping promote ventilation. A midfoot band adapts to the size of your feet, keeping you comfortable and secure with every step.
It’s been a year of revival for classic Nike Running silhouettes. From the OG Nike Tailwind to the nike air pegasus 89 men's Skylon II — which is also being used for a Fear Of God collab — and more, some of the Swoosh’s speediest archival designs have resurfaced for a second go around the track. The latest pair to toe the starting line for a relaunch? The Air Pegasus 89.
The fourth model of Nike’s longest-tenured active running line — which has climbed in number 100% Authentic all the way up to the Zoom Pegasus 35 Turbo — the Pegasus 89 is back in black, as the upper features a combo of black mesh underlays and black suede overlays. A large light grey Swoosh appears on the midfoot, and bright blue accents come to both the heel and top two lace holes. A sleek white midsole then completes the look.
https://www.scratchlin.com/
