| Bremont ALT1-C GRIFFON BRACELET Replica Watch http://velouostas.lt/forumas/viewtopic.php?f=12&t=82617 |
Puslapis 1 iš 1 |
| Autorius: | BreitlingChronomat [ 2023 Gru 14 11:15 ] |
| Pranešimo tema: | Bremont ALT1-C GRIFFON BRACELET Replica Watch |
Bremont's ‘most significant' launch yet, its British-made movements fully rolled out across core products For the first time in half a century, British-made mechanical movements were mass-produced on British shores. best luxury watches For the first time in half a century, British-made mechanical movements were mass-produced on British shores. The result means Bremont is able to roll out the ENG300 into its core products of The Supernova, The Fury and The Audley. The movement was originally introduced in the limited-edition Longitude in 2021, and the ENG300 has been designed to match Bremont's unique specifications. To bring this proprietary range of movements to fruition, The Wing implemented a new production line for machining base components and T0 assembly, which required significant investment in new machinery, staff and training. All Bremont replica watches for sale equipped with the ENG300 movement are rigorously tested to the Bremont H1 timing standard, which is directly comparable to ISO3159:2009 observatory testing. In addition, Bremont is testing the ENG300 series equipped with rotors and complications in the same factory where the watches are made. Testing the movement with all complications installed and running reduces the possibility of performance differences associated with testing an incomplete movement. Testing without the date disc and automatic winding mechanism is common practice, but excluding important subsystems was never an option for Bremont. To ensure extremely high durability (although not a standard part of the H1 test), Bremont placed the ENG300 in a concept case and conducted it on a live ejection launch with brand partner and leading ejection seat manufacturer Martin-Baker carry out testing. high quality cheap watches The Bremont H1 Chronograph Standard pays homage not only to Bremont's hometown of Henley-on-Thames, but also to Harrison's first “H1” marine chronometer, famous for solving the problem of measuring longitude at sea. One of the most famous watch testing observatories in history is the Kew Observatory in the UK. Revitalizing chronometer testing in the UK is a goal that Bremont has been committed to for a long time. All ENG300 watches come with a 5-year extended warranty upon registration. Giles English, co-founder of Bremont, said of the launch: “This is the most important launch for our business because we are finally able to scale up production. Being able to introduce the ENG300 movement into our core watch range and invest in our own chronometer testing represents a huge step forward for us as a business.” Supernova The Supernova is Bremont's first integrated strap design and took 3 years to create, meticulously crafted by Bremont's in-house engineers to extremely tight manufacturing tolerances. replica Urwerk watches Commenting on this, Nick English said: “Not only were we faced with the challenge of scaling up movement production in the UK, but we also had to invest further in case finishing to create the new Supernova, whose final finishing Beyond the standards of luxury watchmaking. "Very few watch companies are able to manufacture high-quality watch cases in-house, and it's clear to us why this happens so often." The Stainless Steel 40mm Supernova is a modern timepiece with a new Trip-Tick case that somewhat improves upon Bremont's classic three-piece case construction through 9 key design modifications, realized with graceful curves and angles Clear, refined beauty. The Supernova collection consists of three different dial colors: Midnight Blue, Jet Black and Albus White. The layered dial features the classic Bremont raised center section and sunken large date function, surrounded by concentric decorative lines. The dial ring features a minute track and markers for every 5-minute intervals, and is coated with Super-LumiNova. for optimal legibility. The 65-hour power reserve design reflects Nick and Giles' passion for all things mechanical. The Supernova Midnight features Applied Baton markings, while the Supernova Pitch and Albus designs feature Applied Arabic numerals, all filled with blue Super-LumiNova. Turning the watch over reveals the exhibition case back, where the ENG375 movement and decorative oscillating weight can be seen, protected by a rubber shock-resistant movement base. furious Aviation has been at the heart of Bremont since its inception, with both brand founders growing up in and around aviation and being pilots themselves. In line with this, the Fury is designed as a classic three-hand pilot's watch. replica Richard Mille RM 35 watches The name pays homage to some of the world's most famous fighter aircraft, from the 1930s Hawker Fury to the 1940s World War II Hawker Sea Fury, perfectly aligned with the brand's aviation heritage and aviation-inspired collections. Full of Bremont's signature design codes, this 40mm chronometer is powered by the Bremont-made high-performance ENG365 movement with date and 65-hour power reserve. The Henri-Made polished stainless steel Bremont Trip-Tick case construction features a scratch-resistant PVD-treated case and is available in two versions: traditional black or rich Bremont blue dial with a complementary calfskin stitched strap. Audley Available in 18-karat rose gold or polished stainless steel, the 40mm case design is the epitome of sophistication. The purity of the design is evident at first glance with its beautifully polished case, fluted and faceted hour markers, tapered hands, recessed date function and power reserve subdial at 6 hours. The silver sunray dial almost sparkles, further accentuated by a blue seconds hand and matching power reserve hand. The new Bremont ENG365 movement once again has a 65-hour power reserve, which can be seen through Audley's open case back. As with every generation of H1, Audley has been tested to Bremont's exacting H1 timing standards. A croc-embossed leather strap complements the overall aesthetic for formal occasions, while a chocolate-colored strap complements the 18-karat rose gold and polished steel versions. replica Franck Muller watch |
| Puslapis 1 iš 1 | Visos datos yra UTC + 2 valandos [ DST ] |
