Paskutinis prisijungimas: Dabar yra 2026 Lap 23 11:43
StandartinėParašytas: 2022 Kov 11 11:54
Pranešimai: 19
Audemars Piguet Royal Oak Chronograph 50th Anniversary Reference. 26240OR A few weeks ago, we brought you a hands-on experience with the 50th anniversary reference to the new Audemars Piguet Royal Oak Chronograph perfect watches website. 26240ST stainless steel, today we bring you the rose gold version on a blue alligator leather strap with a Bleu Nuit, Nuage 50 hue -blue- dial. As mentioned earlier, the AP Royal Oak Chronograph has undergone several iterations and facelifts since its introduction in 1997-1998 under reference number 25860. Even after so many changes and upgrades, the Royal Oak Chronograph does not feature an internal column wheel chronograph until March 2021, when it will only be available in 18K rose gold.
Together with the 38mm Royal Oak Chronograph Reference. 26715 series, new 41mm Royal Oak Chronograph ref. The 26240 series has also been released to celebrate the 50th anniversary of the Royal Oak. While retaining the aesthetic codes of the original Royal Oak designed by Gérald Genta, these new references feature subtle changes in case, bracelet and dial design. Additional models in 41 and 34mm will follow in the second half of 2022 to continue the Royal Oak Jubilee. Currently, the new models are available in stainless steel or 18K rose gold, like the one we have here.
Below is the new Royal Oak Chronograph 50th Anniversary reference. The case of the 26240OR.OO.D315CR.01 has been slightly redesigned to make the watch appear slightly wider and slimmer.best replica watches
For this new version of the Royal Oak Chronograph Reference 26240, Audemars Piguet has made slight changes to the case by enlarging the bevels (chamfers) to enhance the light effect between the satin and polished surfaces and make the watch look Slightly wider and thinner.
In addition, the case back is slightly more fused with the middle of the case, making it more comfortable to wear on the wrist. To accentuate the new case design, the first four links of the bracelet are now trapezoidal and more tapered. Finally, the links throughout the bracelet are thinner and therefore lighter, providing additional comfort and ergonomics. Unfortunately, at the time of this review, we were unable to obtain the 18k rose gold on the bracelet. However, you can see our review of the Stainless Steel Royal Oak Chronograph. The 26240ST on the bracelet is here. For watches on alligator leather straps, the buckle has been redesigned for a more comfortable fit.cheap fake watches
Regarding the watch face, many changes have also been made. The size and width of the luminous faceted hour-markers have been standardized across the different models throughout the collection, regardless of diameter or metal, in order to be cohesive in terms of proportions. In addition to the markings, the normally applied "AP" emblem and "Audemars Piguet" imprint at 12 o'clock have been replaced by the newly applied "Audemars Piguet" emblem, in which each letter is connected to each other by links about the size of a human hair.
This new logo on the Royal Oak's 50th Anniversary model features the same design and construction as the logo first introduced by Audemars Piguet for Code 11.59. The logo is made from a thin layer of 24K gold obtained through a chemical process similar to 3D printing, called galvanic growth. Finally, the minute track previously printed on the webbing now appears on the flat outer area.
New Audemars Piguet Royal Oak Chronograph 50th Anniversary Reference. The 26240OR is powered by the automatic movement 4401, visible through the back of the watch's sapphire case. First introduced in the Code 11.59 collection in 2019, the movement was introduced two years later to power the Royal Oak Chronograph. 26239 or .high quality replica watches
The movement features a column wheel and flyback to restart the chronograph without first stopping or resetting. The chrono button feels like butter when pressed to activate the function, and there is zero hand jitter.
Consisting of 381 parts and 40 jewels, the self-winding calibre 4401 offers a power reserve of 70 hours while beating at 28,800 vph. The movement features a special "50 Years" oscillating weight - which will be installed on all watches in 2022 - in 22K rose gold.
On the wrist, the new Royal Oak Chronograph 50th Anniversary reference. refer to. The 26240OR.OO.D315CR.01 has the exact same dimensions as the previous reference 26239. The strap is more comfortable thanks to the redesigned clasp, and despite its heavy construction, the watch is not too top-heavy to wear overall. On bracelets, it's definitely a different story.Corum Black Ti-Bridge Replica watches
