Paskutinis prisijungimas: Dabar yra 2026 Lap 23 11:07
 Pranešimo tema: eco farm rosin press
StandartinėParašytas: 2021 Lap 10 12:09
Embossing machine is an indispensable machine for industrial production. There are various brands of embossing machines on the market. Our brand of embossing machines is not only affordable and high quality, but also has a variety of styles for you to choose from. Here is one of the embossing machines for your reference.
If you want eco farm rosin press, let’s introduce one of our brands pure pressure rosin press.
Description:
5 tons of Pressure: ECO Farm 5 ton rosin press machine hydraulic device gives big enough pressure on the plate to get better high-pressure oil extraction.
Intelligent Control: Intelligent temperature controller with screen and timing button. With upper and lower heating plates so that objects can be heated evenly.
Humanized Design: Ergonomic handle design for easy pressing and moving.
High-quality Material: The surface of the heating plate is coated with a high temperature resistant anti-sticking layer, which is easy to clean and anti-oxidation.
Product details:
Heat Plate Size: 6 cm x12cm(2.4"x4.7"); temperature range: 0-250 ° C (0-450℉)
LCD Display: Intelligent LCD display is used to display the constant temperature controller, and the temperature control is accurate (±10℃).
If necessary, you can visit our official website for more information about rosin press:ecofarmgreeninc
