Paskutinis prisijungimas: Dabar yra 2026 Lap 23 07:43
StandartinėParašytas: 2021 Spa 26 09:27
Recently, we are engaged in a Halloween promotion. A 10% discount on all products on the site. The discount code is Halloween10. The event will end on November 3rd. If you are interested, hurry up and buy it. And i if you are in hurry ,there are a lot of stocks in the US warehouse recently,shipped within two to three days,you can click here:USA warehouse
Here are two of them:
NO.1: quizz disposable vape 4000 puffs comes with 4000 puffs of succulent e-juice and 650mAh battery capacity. As for the pods, the capacity is 12ml, which can meet your daily use. Pre-fill and pre-charge disposable vape pen kit with Nic salt 5% for vapors and help smokers switch to vapors. With draw-activated design, disposable vape device is easy and simple for vapors daily use. In addition, QD30 Plus features mesh coil and RGB flash light designs, too. 10pcs each pack.
Main Features:
1. RGB flash light, 4000 puffs
2. 12ml of prefilled e-juice
3. 5% nic strength (50mg)
4. 650mah rechargeable battery
5. Draw-activation firing mechanism
6. 12 flavors, mesh coil
7. Micro USB charging port
NO.2: dovpo topside dual is an updated version of the Topside. This game changing squonk mod has all the innovation from the original single battery TOPSIDE but now offers more power and extended battery life. Powered by dual 18650 batteries, the Topside Dual can fire up to 200W with switchable power, bypass, and temperature control modes. On the control face, you have a 0.96" OLED display with a vertical menu that adopts blue font for easy viewing. Meanwhile, it offers a large 10ml squonk bottle eliquid capacity (backward compatible with original topside bottle and sled), simple top filling and an easy to use interface which makes this the perfect addition to those who want more power and extended battery life. Powerful and simple squonking is waiting for you! 8 colors are available.
Technical Data:
Material: Stainless Steel
Juice capacity: 10ml
Battery capacity: Dual 18650 Batteries
Wattage Range: 5-200w
Voltage Range: 1.0-12.0v
Resistance Range: 0.08-3.0ohm
Charging Standard: 5v/2A
Screen Size: 0.96’’
Working Mode: VW, Bypass, TC
Thread: Gold-plated Spring Loaded 510
Color: Black, Red, Silver, Blue, Gun Metal, Gold, Green, Purple
In addition, our website also has other e-cigarette brands and products.
elf bar crystal 2500
scar p3 coils
