v e l o u o s t a s
http://velouostas.lt/forumas/
Virgin materials are of higher quality than those recycled
http://velouostas.lt/forumas/viewtopic.php?f=12&t=82541
Puslapis 1 iš 1
Autorius:  allenlu [ 2021 Spa 19 11:08 ]
Pranešimo tema:  Virgin materials are of higher quality than those recycled
The early paper-recycling industry grappled with this challenge. Converting used paper products into a high-quality paper of the same brightness as the original proved challenging. Additionally, the cost of recycling the paper proved to be much greater than dumping it in a landfill. Manufacturer of Tire Shredder
The exception to this problem existed in aluminum and steel recycling, where new products routinely contained 25% recycled material. Without increasing production costs significantly, these metals could be melted and mixed with pure metals to create new products with the same properties. Regardless of the initial material used, the end product was the same.
For waste tire recyclers, it is not feasible to recreate a new car tire from the rubber of old tires. However, there are many products made from tire and truck tire rubber that meet or exceed the standards consumers expect from similar products. One notable example is rubber mulch. A popular alternative to traditional wood mulch, rubber mulch is a common addition to playgrounds and planter beds. It lasts longer than wood, allows water to reach plants better, cushions playground falls flawlessly, and even helps minimize insect infestation. This new recycled product could be considered a higher quality alternative to the original.
The most concerned matter is the tire recycling machine price when someone invests this equipment.
https://www.phpbb.com/
