If you are a newbie and looking for help to connect your Garmin Edge device to your computer system, the following steps will help you with this:
Pull up the weather cap from the USB port.
Now, take the USB that you have received with the device.
Next, plug the small end of the USB in the device's port and another larger end in the system port.
That's it, now you can see your device in the removable drive in your computer system(for Windows) or in the mounted volume(for Mac).
Note: To prevent corrosion, always put the weather cap.
Garmin Map Update | Garmin GPS Update | Garmin.com/express | Garmin Express Updates
