Paskutinis prisijungimas: Dabar yra 2026 Lap 27 02:05
StandartinėParašytas: 2020 Gru 02 04:30
Užsiregistravo: 2020 Gru 02 04:05
Pranešimai: 5
"Like most previous iterations, the latest option sets the stage for its colorful accents with a neutral-colored nylon base. Suede panels across the forefoot, midfoot and heel, however, also boast muted arrangements. Therefore, the “Photo Blue” hue that takes over profile swooshes appears more pronounced. Exposed stitching throughout the upper deliver stark “Black” contrast; eye-stay covers and branded leather overlays at the rear follow suit. As the “Crater” in its model name denotes, this nike outlet features the speckled material all-throughout the sole unit, with outsoles opting for a dark grey palette.
</br></br>
For Fall 2020, the model has returned yet again with a bright and full coating of shoelessno.com. Though a brand new offering, the scheme evokes similarities to some of the best in React past, contrasting the cool tone with a subtle bit of dark burgundy. The latter shade outlines the eye stay loops atop the instep, the rivets at the midsole, and even the inside lining of the tongue and collar. Elsewhere, Cerulean, Green Abyss, and the aforementioned blue lead atop the upper, each placed in a way that visually mimics a traditional construction.
</br></br>
While not entirely understated, the inaugural nike air max 270 is much more tame than previous non-weatherized releases. “Black/White” take over the majority of the pair’s water-repellent shroud and overlays, as well as rubberized mudguard. Two “Team Orange” ergonomically-shaped zippers beside the tongue, however, interrupts the monochromatic color scheme. Swooshes and reflective accents throughout the upper deliver personality to the model, which dons a “NO BAD WEATHER JUST GOLF” message on the lateral midfoot. Sole units boast a plump Air Max unit at the heel, and feature a traction arrangement specifically designed for both enhanced grip in sloppy conditions and rotational movements.
</br></br>
The nike air force 1 then rounds off the quartet with two varieties. A traditional make-up spices up the usual triple white scheme with new textures, implementing aggressive perforations to the underlying base and a robust, ballistic mesh to the overlays. Swooshes then stamp across the profile in dark black, laid parallel to the tongue whose strap wraps horizontally with light green webbing. And though it may mimic in some ways, the Air Force 1 Shadow is effectively a stark departure as it opts for a more varied palette and an more involved construction replete with extra layers, neon contrast stitch, and vibrant yellow laces.
Paveikslėlis"
